Loffgren said:Can you put recessed lighting in a garage? New construction?
Loffgren said:The HO said they were told no due to the "fire break" Not that i am inclined to belive them, i was just looking for proof that said ya/nay..
Dennis Alwon said:Is there a room over the garage. That may be an issue although I never heard that. I suspect the can would have to have a fire rating in that case.
Loffgren said:No rooms above just gargae attic space...so sounds like its a go???
brantmacga said:i've installed them in garages w/ no problems from the inspector. about the fire separation, i don't see any difference between the recessed light and the box for overhead door receps or surface mount lighting. anyone else?
There was a company at the Vegas CES in Jan this year that had a fire rated speaker can. I'll have to look it up if you need. got lots of biz cards and stuff.raider1 said:The IRC (Internation Residential Code) requires that if habitable space is located above a garage then the garage must be separated from the space above by 5/8" sheetrock. So the recessed cans would have to have a fire rating equivalent to that of 5/8" sheetrock, or have a sheetrock box built around the recessed can that provides the seperation.
I have had issues in the past with speaker cans installed in garages with bonus rooms above them. I have not seen a speaker can that had a fire rating.
Chris
I had a inspector turn those down a couple of years ago. Maybe it was not rated yet?????ultramegabob said:
Sierrasparky said:I had a inspector turn those down a couple of years ago. Maybe it was not rated yet?????
Sierrasparky said:There was a company at the Vegas CES in Jan this year that had a fire rated speaker can. I'll have to look it up if you need. got lots of biz cards and stuff.
