- Chapel Hill, NC
- Retired Electrical Contractor
Wanna Bet.220/221 said:OK...let me re phrase.
I'm sure I can.
I'm sure I can.
Is that a T@B or ENT fitting?stickboy1375 said:whats the story with the red thhn's coming through the plastic NM connector?
Last time I sent you money you didn't even say thanks.Dennis Alwon said:Send me a check for $125
frizbeedog said:$125 for a Photo Shop Job?
Good money. :grin:
chris kennedy said:(BTW the X-ray glasses didn't work)
220/221 said:Will it be listed? No
I tried a Seimens 12/24 and it was way to big.
Panel board enclosures are not required to be listed by the NEC.
The dead front part hits the back box thus holding the cover off the wall.220/221 said:Do you have a drill?
Can't you simply drill some new mounting holes?
220/221 said:Isn't there some sort of remanufacturing thing somewhere that applies to everything including coverplates?
was the panel located over a black hole?stickboy1375 said:What? You've never dropped a screw and couldn't find it? :grin:
Probably got thrown out during demo. I can see that happening pretty easily.Pullnwire said:was the panel located over a black hole?
mdshunk said:Probably got thrown out during demo. I can see that happening pretty easily.
One that I know of.Sierrasparky said:do you have a bone yard in your area?
In Los Angeles there are a couple good places...
Sub with EGC's landed on neutral bar.Also is that service or a sub?
Is the Ground bus insulated ?
Is the ground bus attached to the nuetral bus?
chris kennedy said:Sub with EGC's landed on neutral bar.
That's awfully expensive.normbac said:western enterprises they will ship it 951-683-7998
