I have some questions and I appreciate any help I can get.
Is there a minimum horizontal clearance for a ceiling light? In a basement room the ceiling is about 9 inches lower around some duct work, the light fixture in the room will be on the higher part of the ceiling. Is there a requirement for how far the light must be from where the ceiling drops (essentially a 9" vertical wall)?
Is a panel outlet required? Now that the basement is being finished, is the outlet just below the breaker panel required to be there or since there is an outlet within 6ft of the panel, may this outlet be removed?
I would like to add a light in a crawl space (approx. 3 ft tall). What are the requirements for a light in a closet or crawl space (bulb guard, etc.)?
Thank you in advance!
