Horst
- Valrico, FL
So, we have a new type of "duplex" (city calling it that) and they are stacked. 1st floor is one unit, second is the 2nd unit. The floor of the top unit is 3/4" gypcrete on 3/4plywood over scissor truss, then hat channel and 5/8" sheetrock. This entire assembly is designed as a 1 hour fire separation. We are using Tenmat caps over all of our recess cans https://www.tenmatusa.com/fire-rated-light-enclosures/ff109-300-ul-fire-rated-recessed-light-cover/ and have built 12 of these so far. Inspector came in today and says we need to wire them in MC because we are in the fire "cavity". Keep in mind these are wired in NM, the NM goes through the vent that tenmat provide for this reason, and it is fire foamed at each location where it goes to the switch box. I have racked my brain, researched everything to no avail. I have used NM in this application for years in both walls and ceilings (although ceiling less common) Not that this makes it right, and I cannot even justify with the NEC.... So.... we wire in MC from now on?
