luisnunes230
- US
Hi, the inspector inspector failed the rough inspection because the 200amp main panel (and only panel in the house) it's installed in the garage but although the garage it's connected to the house does not have direct access to the house. Or you use the front roll up door to get access to the panel or use the back door. He claims that in case if emergency it's readbly access.
Is there a NEC article that depicts what he claims? I don't want to move all the wiring together with the panel to the basement.
Thanks
Sent from my LYA-L29 using Tapatalk
Thanks
