David Goodman
- Pahrump, NV, USA
I am having a licensed electrician replace all of my breakers in two weeks. It was hard to get an someone to come look at my panel because new construction is picking up in my area. I hope that is a good sign for all of us.
I have several questions related to this work, and a somewhat lengthy description. I will greatly appreciate a thorough comment from you. It will help me provide good information to my HVAC customers.
My home was built 18 years ago. I have been seeing numerous customers with questionable breaker panels similar to mine. So, I decided to take a look at mine.
It appears to be a Cutler-Hammer side-by-side 200 amp. meter socket/breaker panel. On simply opening the access panel, I noticed that the entire dead front appeared to be out of alignment with the breakers. The first picture below shows how the breakers are tight on the left, but there is a gap on the right. The second picture shows a broken mount for the interior assembly.
When I took the dead front off, I noticed corrosion near the screw terminals. So, my first questions are:
Is this normal?
Does this indicate any particular problem?
Would replacement be recommended based on the corrosion alone?
Several breakers just simply look old. The plastic is discolored. This panel is on the East side of the home, and is exposed to morning sunlight. The temperature in the summer can get in the 105º to 115º F range.
Is there any recommendation to replace breakers in this type of environment after a specified period of time? In other words, are breakers similar to definite purpose contractors in that they have a limited life expectancy? I personally would much rather have a planned outage for one day while the breakers are replaced, than to have an unexpected outage at what would likely be a very inconvenient time when one fails.
I am having the work done primarily for my peace of mind, and I am having a licensed electrician do the work so that I will have documentation for a potential buyer of my home down the road. If I am not willing to have my own panel serviced by an electrician, then how can I recommend this to my customers? (rhetorical question here)
Again your thoughts will be appreciated.
Is this normal?
