We never bothered when we did residential. I've seen on some forums where inspectors are using plugin voltage testers to see if there is excessive voltage drop on a circuit. Although that is unforceable in the NEC I've heard that in some jurisdictions VD compensation is part of their energy code.
This is what I normally see from inspecting. The aforementioned treadmill being a "heavy load" exception.For me, it's #14 everywhere that #12 wasn't required. Also, as mentioned, I make exceptions if I know there will be heavy loads.
This is my method to. Some times around the foyers or halls where vacuums will be pluged in. I'll put a 12.For me, it's #14 everywhere that #12 wasn't required. Also, as mentioned, I make exceptions if I know there will be heavy loads.
First RCA Color sets ('CTC-100') in 1954 using the CTC-2 chassis had 36 tubes.14 should be fine for most residential, at least in my opinion. Most people seem to think all the electronics today are increasing loads, but I remember TVs and Radios with tubes, those things were like space heaters
With the exception of SABCs, I see no reason to run #12 for receptacles. Everything is getting more energy efficient anyway.
-Hal
VD should not be a concern. If you have HR's greater then 100Ft from a main panel then you didn't do your homework on circuit distributionGeneral purpose receptacles, 14/2 or 12/2 ?
Anyone take into account VD for long home runs?
Always wired all receptacles in #12 and lighting in #14.
Just curious as to others practices.
The prototype CTC-1 (never commercially produced) had, according to rumors, 42 tubes, no examples of it remain
more here http://www.earlytelevision.org/Reitan/gallery_index_v2.02_11-20-2006.html
#12 is a pain in a 22 cu. in. single gangI do 12 for receptacles and 14 for lighting just add the cost in, you get some you loose some, but you cant do them all anyway. We still have some old timers around here that refuse to use anything other than 12 on everything. 12-3 is a pain to work with in a pancake box!
