35. A permanent generator is installed on the ground outside a building. The generator feeds a computer room and the air conditioning equipment for the building. If the generator is installed inside a locking enclosure, does there have to be a disconnecting means on the exterior of the building for the feeder?
Loads supplied by optional standby systems are loads that if lost can cause physical discomfort, serious interruption of industrial processes, damage to process equipment, or disruption of business. The loads listed in the question seem to fit these requirements.
A generator set typically has an integral circuit breaker that provides overcurrent protection for the generator as well as providing overcurrent protection for properly sized conductors serving the load connected to the generator.
Section 702.11 was added in the 2005 Code which allows a readily accessible disconnecting means on, or part of an outdoor generator set to serve as the disconnecting means required by 225.31 when installed within sight of the building or structure supplied. To be considered within sight the equipment must be visible and not more than 50 feet.
Is the generator set considered readily accessible when installed within a locked enclosure? Ready access is not considered to be denied by a locked door or enclosure. Equipment would not be considered readily accessible if a snow blower, snow shovel, or ice pick were required to get to the disconnecting means.
Ready access in not denied by a lock when authorized persons with keys are readily at hand. An additional disconnecting means would not be required if the generator was otherwise readily accessible.
