JamesPariseau
New User
- Annapolis, MD
- Electrical Contractor
240v 50amp 3 wire GFCI Disconnect in Garage to Hardwired 240v 3 wire car charging system
No Neutral Required.
GFCI breaker should work without neutral if ground bar and neutral bar are bonded? correct?
Even if we run a neutral to the disconnect, isn't it redundant since there is no load to create imbalance that the GFCI essentially protects?
