A residential hood rated to move
1200 CFM of air is way overkill.
The size of a residential hood (MUA) doesn’t need rocket science to figure out the CFM rating.
Generally. . . the size of MUA (if you need one) is based on the size of the stove/range cook top.
Residential size of stove/range top is 32” wide some are 36”.
Since most ranges come with ovens they are also factored in.
Regular homes do not really need MUA. . . but if the owner wants it. . . it is fair to say that
“customer is always right”. lol
You did mention that the owner asked you to install the hood-- which means they already have it.
Just make him aware that every time he is using the hood vent –doors inside the home would slam close or open depending on the orientation.
It could also suck the conditioned air out of the house.
MULTIPLY the width of the range by 10 to arrive at the right CFM for moving air.
So, if you have stove/range with 32” width you will end up with 320 CFM of air needed to be moved- - which is ample for consumer size hood.
If it turns out to be oversize . . . throw-in a speed regulator.
The max size of hood that requires makeup air is over
400 CFM.
Try this site:
This article looks at what makes a good CFM for a range hood and the reason why it is important when purchasing a new range…
rangecraft.com
or
Ask Mr. Google.
Note:
Keep mind that some older homes have their water heaters or furnaces indoors but they are required to have their non-motorized MUA.
It is just an opening on the wall or floor if it’s raised floor.
Also, the interlocking scheme for MUA motor has been explained in details by other posters.
Good luck
