sminor
- torrance, california
is there a code section that specifies light circuts and receptacle circuts must be seperate?
sminor said:is there a code section that specifies light circuts and receptacle circuts must be seperate?
sminor said:so would that mean you could put all bedroom outlets on one arc-fault, lights smoke and receptacles?
roger3829 said:sminor said:is there a code section that specifies light circuts and receptacle circuts must be seperate?
Only in kitchens
dnem said:Only in kitchens [210.11(C)(1)]
Laundry [210.11(C)(2)]
+ Bathrooms [210.11(C)(3)]
altho with bathrooms there is an exception that can be followed to combine lights and plugs but isolate the room [210.11(C)(1)x]
mistermudd said:Really seems like inspectors really need to be careful what they say around here. Why the sarcasm for just asking a question???
acrwc10 said:I for one APPLAUD an inspector that asks any question here to expand his/her ability to do there job better. I run into many combo inspectors that are very strong in one area and not so well versed in another. There is far to many things to know about building to jump on a person for asking an honest and reasonable question.![]()
roger3829 said:I would be a little leary if I saw one arc-fault breaker in a house. As a rule of thumb, I use 3VA per square ft. for general lighting load. 120v times 15a is 1800VA divided by 3VA is 600 sq ft. Shouldn't see more than 600 sq. ft. on a 15a breaker. Most of the time there is hallways, closets & bath lighting on the bedroom circuit. Unless it is a small house there should be more than one AFCI.
LawnGuyLandSparky said:Why don't you tell US, Mr. Senior electrical inspector?
roger3829 said:4 bedrooms, 5 receptacles in each bedroom, (no lights) plus smokes on 1 AFCI. Not a big deal. The rest of the house on regular breakers.
Not the way I would do it but it would meet the code requirements.
