littleredbirds
- Albuquerque, NM
Newb here... I am about to start filling out the panel schedule attached, but I have questions....
1. What do you make of the derate per chapter 9 statement at the bottom left of thd table? I looked in chapter 9 of nec 2014 and it seems they might be mistaken in their reference. Is the deration intended for the total or individual branch curcuits?
2. I am somewhat familiar with running load calcs to size for a house using the squarefootage of a home, but am a bit confused when it comes to determining the exact load of individual branch circuits. For receptacle circuits I figure I can use the 180VA rule per receptacle, for lighting I can use actual fixture ratings, and for motors I can use nameplate ratings and nec motor tables, but im not sure if I should include toasters, microwaves, ceiling fans, etc. Am I following the right approach here? Since they are asking for branch circuit loads I sould think they want actual loads installed/used in the house and not the pre-construction load calcs used to size the panel and circuits. If anyone knows of a guide, section in code, or is familisr with running branch circuit load calcs post construction, can you please help?
Thank you.
Thank you.
