dm9289
Industrial Maintenance Electrician
- Pennsylvania
- Industrial process repair/ maintenance Electrician
In my area we are using 2017 Nec and we do not use outside disconnects. From bottom of meter socket se cable goes inside house to main breaker panel. The green ground screw is installed.
So in my thinking at this point grounds and neutrals can be installed separately on same gnd/neutral bar. In this panel the right side was neutral bar only till ground screw or bonding jumper was installed, left side was originally gnd bar only. In addition in this panel there were 2 other gnd bars one at bottom left one at top right. I was told you need to run a jumper from the neutral bar to the ground bar top right i did not understand this because i thought green screw made the entire case same potential. I was told you don't want neutral current on case but in my thinking even if you add jumper some of the current will use the case.
Please help me understand this
s
s
