c2500
- South Carolina
This is new construction. You are operateing under the 2003 IRC which I believe is the 2002 NEC.
You have a 200 amp Siemens load center that is used as a sub panel. You need to feed a 100 amp Siemens sub panel that is located approximately 62 feet away.
1. If you were to use copper, what type/size would you run?
2. If you were to run aluminum, what type/size would you run?
I am curious to see if you/your jurisdiction would require the same as mine.
I'll post what mine is later (for those that are interested anyway.)
Thanks,
c2500
Thanks,
c2500
