- Tennessee NEC:2017
- Semi-Retired Electrician
I doubt he was speaking of Wiremold.Wiremold is legal, even if never tolerated.
Because that's what I do.I don't see how you can make that statement without seeing the job.
5-foot DiversiBits are great there, even with a low-pitched roof. The length means you don't have to crawl back in there. You position the tip right at the front of the top plate and start it slowly. After it grabs, you push it against the roof to bend it. As it feeds through the wood, the head straightens. After you drill, use 15 feet of fish stick to go down the wall.If the roof is pitched, how do you drill the top plates from the attic? Especially with interior walls taken out. You might have a lot of nail holes in your noggin before your through.
I agree with @hbiss and the other give him a high price. 1965 house around here the wall probably have at least 2-3" of insulation in thee walls
Few can soldier such livelihood for long:The length means you don't have to crawl back in there.
depends on the roof pitch I guess. If I tried that on the last job I did I would have bored through to daylight.5-foot DiversiBits are great there, even with a low-pitched roof. The length means you don't have to crawl back in there. You position the tip right at the front of the top plate and start it slowly. After it grabs, you push it against the roof to bend it. As it feeds through the wood, the head straightens. After you drill, use 15 feet of fish stick to go down the wall.
There are some other creative options, too
I wouldn't be afraid to price this job by the opening, And I would guarantee 99% no drywall damage
I'm part-time electrician and part-time magician.
I get stuff in with zero damage after 6 electricians say there's no way
