Residential service entrance cable and grounding when using meter socket with main disconnect
jbradley2093
Mid-Michigan
Real Estate Investor
Relevant information:
- 75 year old house being rehabbed with complete rewire
- 100a service
- Meter with disconnect will be mounted to exterior of the residence
The reason for this configuration is that the panel will be on the opposite side of the house as the meter. There is no other option (I could explain, but won't waste your time reading info that does not matter).
It is my understanding that the grounding rods should be near and connected to the meter/main disconnect as its the first point of disconnect, and not at the panel.
Assuming all of the above, does the service entrance cable from the meter socket/main disconnect to the inside panel need to be 3 or 4 conductor? My electrician said we will use (SE-U 2-2-2), but it did not sound correct to me. Don't we need a separate ground wire connecting the earth ground outside to the inside panel, separate from the neutral?
I am closing this thread, in accordance with the Forum Rules.
This site is designed for:
  • Contractors
  • Electricians
  • Engineers
  • Inspectors
  • Instructors
  • Other electrically related individuals
* This NEC Forum is for those in the electrical and related industries. Questions of a "How-To" nature by persons not involved in the electrical industry will be removed without notice.
Reminder to all members, if you see a questionable post, feel free to report it by clicking "Report" at the bottom left corner of the post.
