Michael Abruzzi
New member
- Arvada Colorado
Friends,
I'm an electrical inspector in colorado and have a grounding question regarding service upgrade inspection.
An electrical contractor obtains a permit to change out a residential electrical service. Bonding and grounding are correct at the service power panel however the E.C does not float the neutrals at the down stream sub- panels.
These sub-panels are protected by a main breaker in the service power panel; and are not modified during the upgrade.
This is a two-part question: First I argue that the E.C must float the neutral at the sub-panel, even if it has not been modified and not listed on the electrical permit as part of the scope of the job. secondly, on an older sub-panel with an uninsulated neutral as part of the feeder assembly(3-wires ystem), has the code ever allowed equipment grounds to be terminated on the neutral bar in this type of wiring system?
The answer to this question will resolve a disagreement.
