That can only be answered by the authority the specified that a 17kw genset be used. There's no guidelines for this in the code.Originally posted by william runkle:
Please give an answer why would they require a 17 KW generator?
The inspector might be under the impression your going to transfer power to the whole 100 amp service. Are you positive he knows that the Gen. will only be feeding the circuits in the Sub-Panel?Originally posted by budbla:
The owner plans to install the normal service equipment (for the future), manual transfer switch and a sub panel (to supply the generator loads).
I don't see any hazard. Just poor design. In my opinion, the generator should be sized according to the load it will be supplying . A demand load calculation should be used just like for utility power.Originally posted by jimwalker:
Someone please exsplain to me the hazard involved if i only have 5500 watt gen feeding my house in a huricane.Common since tells you to treat it like green acres and watch what you turn on.The gen. is self protected from overload so whats the problem ?
I'm with you, especially about the "common sense". If it was so common, how come more people don't have it?Originally posted by davedottcom:
</font><font size="2" face="Verdana, Helvetica, sans-serif">
- <font size="2" face="Verdana, Helvetica, sans-serif">Not every person that uses a transfer switch & generator is an electrician with knowlege of how to regulate the loads properly.</font>
- <font size="2" face="Verdana, Helvetica, sans-serif">I don't consider knowlege of electrical theory to be "Common Sense" at all.</font>
- <font size="2" face="Verdana, Helvetica, sans-serif">The "limited" power from a generator needs to be regulated in a "user friendly" way for the "common" person.</font>
That's my opinion and I'm sticking to it!
Dave
IMO it could not be more clear that the homeowner can try to run their entire house from a 5000 watt generator.702.5 Capacity and Rating.
An optional standby system shall have adequate capacity and rating for the supply of all equipment intended to be operated at one time. Optional standby system equipment shall be suitable for the maximum available fault current at its terminals. The user of the optional standby system shall be permitted to select the load connected to the system.
NOOO! Don't even say that..."They" might hear you!Originally posted by iwire:
Would you rather the code required the optionally installed generator to run the whole house?
