It must be accessibleadavey said:Can I splice 2 - 12/2 NM cables in a junction box and then sheetrock over the cover, or does the splice box have to be accessible ????????
M. D. said:
Is that a compression tee?:grin:JohnJ0906 said:MD, who makes these? I was searching for a link to these, and couldn't remember the manufacturer.
The cable can be concealed and fished.... Not the connector.... Well I guess the connector can be fished too - but not concealed....M. D. said:334.40 (B) Devices of Insulating Material Switch, outlet, and tap devices of insulating material shall be permitted to be used without boxes in exposed cable wiring and for rewiring in existing buildings where the cable is concealed and fished. ~~
These interconnecors are insulating devices equivalent to NM cable and can be installed in accordance with Section 33.40(B), so if is being used for rewiring in existing building, it can be concealed and fished.
e57 said:The cable can be concealed and fished.... Not the connector.... Well I guess the connector can be fished too - but not concealed....
Quote:
Dennis Alwon said:Just so you know, my comment was not derogatory at all. It was a response to sierrasparky's statement.
