Fred B
- Upstate, NY
- Electrician
The simplest I've seen that shows the degree of phase difference is not from the view of the sine wave or scope (many residential electricians will never get their hands on a scope), but from the geometry of a triangle. Generally a 3 phase will be drawn as a delta or wye and a triangle with points A, B, C on the corners. As OP had stated the phase shift is 120 deg from reference between C,B,A on delta.
Now on single phase you are only dealing with any one line of the triangle, if you take points A,B and you add a point N in the middle, the degree of reference between the 3 points will be a flatened triangle or degree reference from the three points from N to A or B is 180 degree.
Cancelling out on a single phase doesn't occur in the way you are thinking because that A,B reference are on opposite ends of the triangle line, perfect world and all working correctly, when A is + B is an equally - voltage, the only time it cancels is at the N point, because of the nature of AC power, always fluctuating from a peak value + to a peak value -. Kind of like a teator totter, when one side is up the other side is down, only time it as canceled out is at the N point (or point of pivot) when the teator totter it is flat, but won't remain flat if someone on each end pushing to keep it going (generator). That is what is represented on the scope in the form of a wave pattern, point A and B of the teator totter reacting relative to the pivot point N.
Overly simplistic but should be close to accurate. (Perfect world)
