Residential Well VFDs and LED flicker.
The way the Franklin drives are set up, you can't screw up the grounding without trying very hard. Line side in, one small area, load side out, another area with no open wireway between.
ETA: pretty sure the pump guys install the drive and anything to the well. They are allowed under our state licensing. That part has been cleaned up in the last 20 years.
