I was reading an article on Ground fault sensing using a residual grounding detection method and had a question in regards to 3-Phase 4-Wire Residual grounding. I understand that in 3-Phase 3-Wire residual grounding under normal operation the vector sum of the phase currents is zero but do not understand why in a 3-Phase 4-Wire system the vector sum of the phase currents equals the nuetrual current. Is this because all of the phase currents return to their source via the nuetral. If this is the case, then how do the phase currents in a 3-Wire system return to their source?
I was hoping someone could shed some light on the situation and explain why in a 3-wire system the vector currents equal zero, and in a 4-wire system they equal the nuetral current?
Thanks
Mull982
Thanks
Mull982
