mivey
My thought is that in the normal course of business, the parallel connection across the source tends to have a high impedance component through earth contact or similar whereas a series connection with a load has a relatively low impedance component (the load).impedance of the load is typically much much smaller than the resistance of human body so whether you are in series or in parallel with the load makes virtually no meaningful difference.
That is why I say a neutral shock tends to be worse as you tend to be in series with a low-impedance load through good skin contact (lower caution/awareness due to lower concerns about neutral safety).
A hot shock tends to include a high-impedance path such as earth contact, lower pressure contact, or some unknown multi-impedance meandering path back to the source (high awareness but accidental contact/path closure).
Of course a direct high-pressure contact from source hot to source neutral is worse than either of the two prior scenarios but these tend to be less frequent due to a higher awareness/caution level.
YMMV.
