- Placerville, CA, USA
- Retired PV System Designer
If it turns on the hood it must also turn in makeup air, yes.
One more question,
Should it also turn on make up air as well as the exhaust?, (So not to create a negative pressure in building. The make up air is directed thru duct to the rear of appliances.) and would be energized during normal operation of a wall switch to turn on/off hood ventilation.
The ansul system will shut down make up air, trip shunt breakers, activate horn/strobe and close (cable actuated) gas valve. Sound good?
Yes, that's the intent of the code section. Appliances on, exhaust on.
We seem to go at it in another direction.
Exhaust fan off, appliances off.
Air flow proving switch in the exhaust duct that controls the gas valve. No airflow = no gas.
