Tedh777
- St. John's, Newfoundland, Canada
Hi,
A quick question about the technical feasibility of reversing power flow through a GFCI breaker. The situation is for an installation of a pool heater fed from a sub panel in an outbuilding on a 30A GFCI breaker. The heater is disconnected and stored for the winter. There is a small backup generator, 30A, being wired in to the same outbuilding that will only be available in the winter (stored in the summer). I am just curious more than anything if the now unused GFCI breaker could be used for the generator as the pool heater is disconnected for the winter. I know reverse power on GFCI outlets will not work but am not sure about the same thing for breakers. Will power even flow through a GFCI breaker in reverse or will it trip? What are your thoughts on the circuit design in a GFCI breaker in this situation?
Thanks,
Ted
Thanks,
Ted
