Heard Revit has been used more recently among MEP firms across states, does anyone here work with Revit and know the advantages/disadvantages compared to AutoCAD (especially in electrical design/production application?), how long does it take to learn and how to use Revit?
Many advantages and disadvantages. It takes more time to set up a project, and to set up all the components you want to place in a building. Revit is much better at 3 dimensional modeling. It also does some basic design stuff. It keeps track of all the VA's on the panel schedules, and totals them all up. (But, that means you have to add VA's numbers into each load you connect. ) Move a circuit from one panel to another, and it updates the enitre project including circuit numbers on the homeruns and panelschedules and load calcs.
It even does some crude voltage drop calcs. and wire sizing. It can also do photometric calculations right inside the your model.
How long does it take to learn? It depends. If you are a fast learner, you can start drawing walls and rooms in a hour or two. But after using it for years, it still makes me want to bang my head on the desk much more often than autocad.
Its much more difficult to control what shows up in a view. Trying to place a light fixture in a plan and getting an "Object not visible in view." error is just one of the frustrating things that will have you run up against. Then you have to check the view range, any view regions, view graphics, workset graphics, temporary hidden objects, etc.
It really puzzles me why the error message can't tell me why the object isn't visible, and give me the option to make it visible. I could list about 100 other things that would be on my wish list for Revit.
All in all, Revit is more powerful, but it usually takes longer to do a project in revit.
