Any radio receiver front end is made up of many frequencies, this is called super heterodyne, the cheaper the front end the more IF frequencies, or it may not be coming into the radio through the antenna at all,....
Hurk, you said this in reply to another thread recently too. Since you said it again, I thought I should correct you so you understand what superhyt rcvr means....
I may not get all the words perfect, but after a lifetime as an electrical engineer, of Extra class ham radio and 1rst class commercial licensing (when it still meant something) I think I can explain it some...
In the old days of radio the receiver was simply a cat's whisker into a rock of selenium, or similar material, and it rectified the "input." This input was 'tuned' by having an LC in front of it. As a kid, I, like many others of the Flash Gordon era, used an old oatmeal container to wrap our coil around. We tuned by moving the cats whisker on the rock.....
Then Mr. Armstrong invented the 'regenerative' receiver, then the heterodyne then the super heterodyne receiver. You can google those intermediate ones, but the superhet simply added an oscillator to mix a given SINGLE frequency with the incoming signal or frequency and get a sum and subtraction one. One was thrown away via filters; the other was then used to contnue amplifying the incoming signal. Typically this was an intermediate frequency (IF) of 455kc. By doing this, the selectivity could be increased by magnatudes.
If the input freq is high enough (like fM radio band, then a SECOND IF is used first - typically 10.7Mhz. It is not often that a 3rd IF is used, even today. So you see there is no relation between the 'the cheaper the front end the more IF frequencies" and reality. Actually the more expensive the receiver, the more IF channels.
The superheterodyne receiver has nothing like 'lots of multiple frequencies" on the input compared to any other receiver. Virtually every receiver today is a superhet design - even the single chip receivers.
