- Placerville, CA, USA
- Retired PV System Designer
To the extent that it lets you use a higher upper limit frequency because of its lower attenuation at that frequency the lower loss cable could give you more data bandwidth. But only if the transmission system can make use of that higher end.It will not transmit "more data". It will however carry the given signal with lower losses. At 700Hz, generic RG6 loses about 5.6 dB/100 ft while RG11 is more like 4.7 dB. It adds up.
(Also, it doesn't require special connectors, it requires specific ones for that size and impedance, just like almost all coax.)
And if the system is marginal because of a high error rate resulting from the attenuation, then you could get a higher net throughput from the better cable.
But improvement certainly is neither assured nor automatic.
