Maybe so. But if the situation allowed you to slide in the conduit from the outside it would be fairly simple to have one worker on the outside slide the first length of conduit into the building with another worker on the inside guiding and pulling them through the next set of block outs. The first worker then threads (hand tight only) on the next length of conduit and pushes it into the building. You keep adding lengths of conduit until you reach the center or the other end. You then un-thread the first length of conduit, thread it into the box, mount the box and strap the conduit down. You repeat the process moving back towards the outside of the building from where you started. If the measurement between the center of the T's is a true 5', you would have to cut and thread the lengths of conduit to compensate for the diameter measurement of the light box.
You would have to admit. To the trained eye, you would raise a few eyebrows leaving them scratching their heads.....How did they do that?:huh:
