Actually, it stands for American National Standard Taper Pipe Threads (NPT), and has been abridged in its written form through the years.iwire said:Me too, but Marc's right, Thanks Marc.![]()
Paul B said:I would like to see that, I thought the thread was a function of the dies.
Perhaps the Rigid Model 1224...nolabama said:what kind of threader is that ??
KJay said:Screwing an NPT field threaded pipe into a factory NPSM threaded coupling or box will result in only partial engagement of the threads. It will not be secure, liquid tight, or provide the same level of grounding as a proper NPSM to NPSM or NPT to NPT connection. THE NEC IS WRONG!
KJay said:The problem is that NEC article 344.2, B is in error for anything other than classified locations. It?s obvious that the people on the code-making panel of the NEC know as little about pipe and conduit as the average electrician.
All factory electrical RMC, RNMC [PVC], EMT and liquid tight fittings, couplings, locknuts and WP bell boxes are NPSM threads. Stop buying your rigid pipe at the plumbing supply house. I have both types of threader dies for my threading equipment.
The only place in the NEC where NPT threads are actually required is for hazardous locations where the explosion proof boxes and fittings will also have factory NPT threaded entries. Also with NPT threads, locknuts are not required.
brother said:You say the NEC is wrong??!! THATS BLASPHEMOUS!!! Stone HIM, STONE HIM!!
KJay said:And I am correct.
If two wrongs don't make a right, why do three rights make a left?tryinghard said:What is really right anyway?
Is left right?![]()
LarryFine said:If two wrongs don't make a right, why do three rights make a left?
KJay said:All factory electrical RMC, RNMC [PVC], EMT and liquid tight fittings, couplings, locknuts and WP bell boxes are NPSM threads.
iwire said:Kjay, can you provide a anything more then your say so?
KJay said:I think the easiest thing to do is go to your local plumbing supply house or hardware store .
Here's a little tidbit to throw in the fire...iwire said:Or just check the spec sheet above from the maker and NPT is not special order it is the standard item.
BUT......... I agree, connectors are straight thread.![]()
