- Tennessee NEC:2017
- Semi-Retired Electrician
Most Ring installations are replacing an existing doorbell. All you do is remove the button and replace it with the Ring button/camera. I was checking to see how to hook one up without an existing doorbell. I found instructions for that but have some questions. The instructions said to install a transformer 8-24V, then on one of the low voltage lines you place a 50W 25 ohm resistor in line from the transformer to the Ring button. Now you can run a Ring system wireless but the button has a battery. The problem is you have to take out the battery and charge it with a USB cable. The hardwiring just keeps the battery charged without having to remove the battery. Now I know that a normal doorbell button is just a switch to allow the transformer to connect to the chimes. I'm trying to figure out how running straight to the button from the transformer allows the button to be a switch since you haven't made a switch loop, just a connection. I can only think there must be an internal switch that makes when you push the button.
Just for comparison, if you have an existing doorbell, you just connect the button as usual and not use the resistor. The resistor is just to keep from having too much current/volts from going to the battery. My question is how does the Ring button both make a switch loop for the existing doorbell chime and also be a switch for the Ring system? In the case for direct wire there is no switch loop, but with an existing chime there is a switch loop, but only for the chime. Also, how does the battery get charged if there is an existing chime? Seems it would only charge when the button is pushed.
Can someone "splain" what's going on here?
