I've got a customer that wants to move the meter socket and service conductors to the side of the building and off the front of the house.To do this I've got to use a 2 in ridgid riser above the roof to to keep in line with poco's pole. It's a two story house so if I use a ten ft length at the top for support and install the service bracket at the required height I still have to make up approx four ft from the coupling to the meter hub. If I use the ten ft length on the meter hub it puts the coupling too close to the roof line. If I use a 4 ft cut piece of PVC I'll lose the bond between the hub and the ridgid. If I use SE cable I'll have to put a cable clamp in the coupling and I still have to bond to the ridgid riser. I can cut the ridgid but I can't make 3/4" taper threads that are required for feild cuts.
I'd appreciate any ideas you guys might have. Thanks
