Alwayslearningelec
- NJ
- Estimator
Can you use threadless fittings for these? I assume most of the time you would not use them and if so just for connectors and not couplings.
Coupling also come threadless? Seems like they do. I was only aware of connectors.Yes threadless are permitted but sometimes the spec will not allow them. As far as I know they cannot be direct buried.
Yes, you are correct that both couplings and connectors are available in threadless variants.Coupling also come threadless? Seems like they do. I was only aware of connectors.
I assume nobody would EVER use these opn the end of full sticks that are already threaded and have the coupling.
Elliott Electric Supply - Lower Cost, Quality Electrical Supplies, and Personal Service
Electrical Supplies Distributor. Elliott Electric Supply is your local electric supply house. We Deliver Lower Cost, Quality Products, and Personal Servicewww.elliottelectric.com
