D dominic58 Member Nov 1, 2017 #21 I use copper shield at the water treatment plants, works as a anti seize and helps with conductivity. I also use it in other applications as well.
Fulthrotl ~Autocorrect is My Worst Enema.~ Location HB, CA (19 Hrs. 22 Min. from Winged Horses) Occupation E Nov 1, 2017 #22 dominic58 said: I use copper shield at the water treatment plants, works as a anti seize and helps with conductivity. I also use it in other applications as well. Click to expand... teflon is a pretty good insulator, so that isn't a working solution as mentioned. if you want to exclude water and prevent corrosion, here is what i've always used. http://www.armitelabs.com/products/LP250_Anti-Seize_Thread.html made in costa mesa, calif. for the "buy american" appreciators. on fitted joints, it's good to 50,000 psi. that should keep most of the rain out. 2 oz. tubes to 50 lb. pails.
junkhound Senior Member Location Renton, WA Occupation EE, power electronics specialty Nov 1, 2017 #23 Only job I ever did in HI we used Galvacon (95% zinc base paint) on all threads on buried steel RMC. BTW, buried Aluminum RMC in HI corrodes within a few years due to the high iron and sulphur content of the volcanic soil.
