RMC treads where does the code dis-allow use of thread compounds?
I use copper shield at the water treatment plants, works as a anti seize and helps with conductivity. I also use it in other applications as well.
teflon is a pretty good insulator, so that isn't a working
solution as mentioned.
if you want to exclude water and prevent corrosion, here is
what i've always used.
http://www.armitelabs.com/products/LP250_Anti-Seize_Thread.html
made in costa mesa, calif. for the "buy american" appreciators.
on fitted joints, it's good to 50,000 psi. that should keep most of
the rain out. 2 oz. tubes to 50 lb. pails.
Only job I ever did in HI we used Galvacon (95% zinc base paint) on all threads on buried steel RMC.
BTW, buried Aluminum RMC in HI corrodes within a few years due to the high iron and sulphur content of the volcanic soil.
