Rmp required
Most use a single pair of poles so if the desired AC frequency was 60 Hz the RPM would be 3600.
True for an alternator, but the O/P stated dynamo, which implies DC.
Dynamos can be built for most any speed depending on application.
OTOH a rating of 7KVA, not KW implies an alternator.
Can anyone tell me that how many rpms required for a dynamo of (7kva) to produced at its maximum out put.
Well for a given rated output the speed will be much lower for a dc current dynamo then a alternating current design .
Heres a formula P= number of poles
R= revolution per minute
N= frequency of cycles per second
[ N= PR/2X60 ]
Example 1== KW 1000 POLES 6 RPM 1000 VOLTS 1000
Example 2 == KW 1000 POLES 6 RPM 1500 VOLTS 550
Relation between speed and freq is not how high it is but the balance of the speed to the poles in syn.
