mjf
You guys are silly. Obviously, the generator inlet is out of the picture. Everyone needs to be able to weld when the power goes out.:angel:
OK. So the way the interlock is wired up you can either drive the welder from the bus or drive something else from the bus, but the generator and poco come to the bus from a TS not seen in the photo.You guys are silly. Obviously, the generator inlet is out of the picture. Everyone needs to be able to weld when the power goes out.:angel:
I don't think this is for generators. The toggle and breakers yes, but a NEMA 6-50, not so much.
Also, a NEMA 6-50 does not need a neutral.
