stickboy1375
- Litchfield, CT
josh greene said:I thought they called it wire bundling when u put more than 2 wire in a half inch romex conn?
Check out 310.15(B)(2)
Only if that connector is 24" or longer.josh greene said:I thought they called it wire bundling when u put more than 2 wire in a half inch romex conn?
Reminds me of a joke :resistance said:I guess the joke was corny!
LarryFine said:Don't forget part two of that one:
Another guy stands up and says "143!"
Everyone laughs and nods, but as the laughter dies down, one guy is still roaring in laughter and rolling on the floor.
"What's up with him?" asks a guy nearby.
His friend responds, "He's never heard that one before."
Remember at one point in time it wasn't all that clear exactly what you were supposed to do with the ground wire. Wrapping it around the clamp screw probably seemed perfectly reasonable at the time.Chamuit said:Came across this today. Wonder if any of the old timers used to do this?:grin:
I unwrapped all of the grounds extended them and installed a ground bar on the sub-panel these were in.
This was the era right before "cracker jacks" would just cut the ground out of their way!mdshunk said:Remember at one point in time it wasn't all that clear exactly what you were supposed to do with the ground wire. Wrapping it around the clamp screw probably seemed perfectly reasonable at the time.
