Romex connector?
dwellselectric
Inactive, Email Never Verified
Question came up in class last night I think you can but they say you can't. Can you put a 12/2 and a 14/2 romex under the same romex connector? I think you can but most are saying that you can't??:-?
This would be in the manufacturers information. I know some are listed for more than a single cable, but I don't know if combinations of different sizes is specific to the information.
FWIW, I think you are correct.
Roger
From Arlington's Website...
1-14/2 & 1-14/3 1-14/2 to 10/2 NM
1-14/2 & 1-12/3 1-14/3 to 10/3 NM
1-12/2 & 1-14/3 2-14/2 to 10/2 NM
1-12/2 & 1-12/3 1-14/2 & 1-12/2 NM
2-14/2 & 1-14/3 1-14/2 & 1-10/2 NM
2-14/2 & 1-12/3 1-12/2 & 1-10/2 NM
3-14/2 NM
http://www.aifittings.com/c_19.htm
Edited: Or just use Marc's link... :)
3-14/2 NM
I usually put them under the same and get buy with it. I do apprecitate Marc site and also thanks stickboy for your info. (See) you can teach an old dog new tricks. Semper Fi. Buddy
JohnConnolly said:
Do people still use those metal two screw connectors?
You're saying that like they're some sort of antique fitting. :grin:
Yes, that's mostly what I use. I recently switched to the snap-in version of the two-screw NM connector.
I thought those went out in the late 60's. I still stock them and use them in certain applications but anywhere that I have to use a metal box with MN I go with plastic snap ins (T&B)
There are several different types of snap in plastic connectors.
No lock nut and no screws = easier. No metal = less likely to short.
For multiple cables
For single cables
Can't find a pic but it looks like a plastic snap in bushing with retainer "fingers" in the center.
I curse those box connectors!
I do mostly service work, and as such, I swore I'd never use those connectors. They're a real "treat" to get a cable out of. I'm sure they do make the install fast, however. As far as shorts go... well, if that's a problem for you when using metal connectors, I'm going to commandeer your screwdriver.
I do use the "black buttons" on occasion, for flush items like strip lights and range hoods. They're not so bad to get a cable back out of if the need arises.
I agree with Marc, and I knew you we're going to post a pic of those god awful plastic pieces of garbage!!! :wink:
What do you normally do for two 14-3 or 12-3 in 1 connector?
I used to feel the same way. Then I started working for a company that only buys that kind of connector. You learn to like them really fast. ;)
Since them, I've preferred them over other connectors. I guess they really brainwashed me. :eek:
Does each box of them come with a special packet of Kool-Aid? :D
You company does mostly new work, and not so much service, I'd guess? If I did mostly new work, they'd be what I'd use too.
I like the RCR 50 from Seagull I believe. Can be used inside the box or outside as well. It snaps in with no additional tools necessary to insert/secure the wire.
Tom
:roll:
:roll:
:cool: You'll are testing my Dyslexicness...
dSilanskas said:
Can you put a 12/2 and a 14/2 romex under the same romex connector? ??
What are those new wire nut connectors called... "Wire nut stab-on's" ?
I'll Ketchup, I like mustard too ... Gezz, why did I think Wire nuts ...
:smile: "yes, I'm too lazy to turn a screw driver"
emahler, and I was taught to use screwdriver to tighten set screw on EMT connector. What do you use?:confused: :D :D
