ATTACHMENT PLUGS (AXGV)
GENERAL
This category covers the following types of products:
Adapter
? A device that adapts one blade or slot configuration to another
(including a grounding adapter for a nongrounding receptacle), adapts a
receptacle to a lampholder, or adapts a lampholder to a receptacle (also
known as a separable attachment plug). (See EMDV for similar products.)
Appliance Coupler
? A single-outlet female contact device to be wired
on flexible cord as part of a detachable power supply cord to be connected
to a male inlet of an appliance.
Appliance or Flatiron Plug
? An appliance coupler type of device having
a slot configuration specified for use with heating or cooking appliances.
Attachment Plug
? A male contact device for the temporary connection
of a flexible cord or cable to a receptacle, cord connector, or other female
outlet device.
Cord Connector
? A female contact device to be wired on flexible cord
for use as an extension from an outlet to make a detachable electrical connection
to an attachment plug or, as an appliance coupler, to an equipment
inlet.
Male Inlet (Equipment Inlet, Motor Attachment Plug)
? A male contact
device to be mounted on utilization equipment to provide a detachable electrical
connection to an appliance coupler or cord connector.
Nonseparable Attachment Plug
? An adapter having a male screw shell
and a pair of wire leads to be connected to utilization equipment.
Separable Attachment Plug
? An adapter having a male screw shell and
a slot configuration outlet.
Shore Power Inlet
? A male inlet intended to provide power supply connection
to boats moored to a dock. Shore power inlets are also covered
under Shore Power Inlets, Marine (UBXR).
Table Tap
? A cord connector having more than one outlet and intended
to rest on a horizontal surface while in use.
This category does not cover devices to be molded on flexible cord or wire
and unassembled devices to be factory assembled on flexible cord or wire.
Such devices are complete only after installation of the flexible cord or wire
and they are judged as part of a complete assembly.
Ratings
These devices are rated 600 V or less, ac or dc, and 200 A or less. They
may also be rated in horsepower as noted in the individual product categories.
Outlet devices rated 250 V are tested on circuits involving a nominal
potential to ground of 125 V. Outlet devices having other voltage ratings are
tested on circuits involving full-rated potential to ground, except for
multiphase-rated devices, which are tested on circuits consistent with their
voltage ratings, i.e., a 120/208 V, 3-phase, device is tested on a circuit
involving 120 V to ground.
Terminals
The terminations of devices intended to be wired to flexible cord are
based on the use of flexible cord or cable having copper conductors, in
accordance with Article 400 of ANSI/NFPA 70, ??National Electrical Code??
(NEC). The ampacity of flexible cord and cable is based on Section 400.5,
Tables 400.5(A) and 400.5(B). The conductors are sized as specified on the
product or in the manufacturer?s instructions provided with the device. The
terminations are based on the use of 60?C flexible cord or cable.
The terminations of devices intended to be wired onto branch circuit conductors
are based upon the use of 60?C insulated conductors in circuits
rated 100 A or less, and the use of 75?C insulated conductors in circuits
rated more than 100 A, as specified in Table 310.16 of the NEC.
Grounding
Devices having a terminal identified by a green-colored finish, the words
??green?? or ??ground,?? the letters ??G?? or ??GR,?? or the grounding symbol are
grounding types. The blade, pin or contact number connected to this terminal
is for equipment grounding only.
