LarryFine
- Henrico County, VA
- Electrical Contractor
By the way, the inlet terminals are just like GFCI receptacle terminals, which are okay with solid conductors.
I just checked a 15a twistlock inlet. Nowhere on the box or the inlet does it specify stranded conductors, although the little "strip like this" picture shows starnds, and states to not tin the wires.
I'm not good at navigating the white book so tell me:
How can you tell if AXGV applies or if AXUT applies? From AXUT:
I could be wrong, but I swear I saw them. I just checked my hubbell book and they dont have it, leviton and marinco books arent infront of me.
As far as the wire, the pressure terminals in the cord ends and inlets are designed around the more finely stranded wire found in cord. They work with stranded THHN but i have noticed better contact and conductor retention is made with the more finely stranded wire.
Your price is too low.That is a receptacle. I use white plastic Leviton clock receptacles behind the TV.
Check out 3D189 on the same page. I sold the inlets I made for less than $66.90.
This says it is ok for solid wire:Inlets are covered by the UL text I posted. :grin:
Terminal Accommodation
#18-#10 AWG copper stranded or solid conductor only.
Yeah, but the chips taste terrible.A pringles can is "intended" to hold tater chips, but it works just as well or better as a Paint Roller Holder overnight, so you can get up the next morning and started painting with it again without having to clean it.
Hello All
Long time observer first time poster. I have seen this topic come up a number of times before. Before becoming an electrician I spent many years as a recording engineer and studio technician. A company called monoprice has the following item that neatly addresses this issue. I have used theses guys a number of times and their prices and shipping are incredible. check out the link below.
http://www.monoprice.com/products/p...d=1042505&p_id=4652&seq=1&format=1#largeimage
Another reason to not just blindly follow the instructions.:roll:you can tell in the pictures it must have been a DIY. The hot is wrapped the wrong direction around the screw.![]()
Well, when you get your code book in hand tomorrow please let us know where you find it.
Roger
<snip>A pringles can is "intended" to hold tater chips,
