glene77is
- Memphis, TN
Can Romex EVER be run inside of a conduit?
The attached photo is a 'leading' example,
to intice comments.
to intice comments.
to intice comments.
Well I'll just stick my neck an ask about 300.12. Wouldn't the NM be considered non-metallic cable and the cable sheath needs to be continous?
OK,
This is a DIY.
NM is not listed for underground or damp locations.
This NM is heading down a service entrance conduit.
Anything else.
Any code issues with NM inside a conduit?
Underground and Damp is out, per code.
I say NM can pass from a breaker panel, through conduit,
and out to a light, all in one piece of NM.
That is,
No Transition between THHN in a conduit, into a JB, and then NM to the light fixture.
the NEC doesn't say that you cannot do it.
I thought the op was saying the nm was installed in the conduit. I assumed it is not stripped except at the terminations.
OK,
the sheath must be continuous until it is inside a JB,
then joints made to transition to THHN for the conduit run,
if a transition is required at all.
And 'that' is the question I have.
Why can't I run NM from the light fixture, straight through to the Panel ?
I think I can, by code.
I can't find a code reason for any restrictions,
but my fellow workers say 'no'.
btw, nice egc connection in the pic. i do not mean to imply that you did it.
I have been told I must transition from Romex, in a JB, and down with THHN.
I maintain that the code allows a continuous run of Romex
from the Breaker Box to the conduit and down to the Receptical.
What if the NM just punch through a grommet in the cabinet? wouldn't it be similar?
