zcanyonboltz
- denver
If I need to make a j box say when changing a service to extend existing home runs to reach the new service location is there an article that discusses romex in gutters? I'll try to post a pic later today. 366.22 says no more than 20% fill. Would you just count up conductors use the volume allowance for each conductor from 314.16 (B) or you could use chapter 9 wire approximate area to determine fill?
Another example is I've seen old indoor panels gutted and used as a j box and then new wire is run to the new panel outside the house.
