Romex Run From Crawlspace In Order To Install A Receptacle Above A Fireplace...
Ravenvalor
Triad region of NC
Hello,
Would it be code compliant to put a receptacle above a gas fireplace if running the romex trough the area that encloses the fireplace? I would like to fish the romex from the crawlspace, over the firebox and to a new receptacle. It seems like the romex might end up laying on the firebox itself and be damaged by the heat. This is a single family residence.
Thanks,
Just don't allow the NM-B to come into contact with enclosure keep minimum clearance from fire box as any other combustible material.
