mtnelect
HVAC & Electrical Contractor
- Southern California
- Contractor, C10 & C20 - Semi Retired
An a/c compressor can be fed with 8 Romex and fused ad 50 amps if minimum circuit ampacity on name plate is 40 or less but requires larger minimum fuse for startup
The MOP is the maximum suggestion limit, but you can use less, if it doesn't trip at that level. It's only a "Suggestion" from the manufacturer.
