We will be performing upgrades on the forums and server over the weekend. The forums may be unavailable multiple times for up to an hour each. Thank you for your patience and understanding as we work to make the forums even better.
Good luck finding anything with 90C rated terminals though...
This concept basically only applies when connecting directly to bus bars using compression lugs, and even then not all compression lugs are rated for 90C.
