larrybader
Please Provide the Code information, when installing new HVAC on the Roof, Service Receptacle and light is required?
larrybader said:Please Provide the Code information, when installing new HVAC on the Roof, Service Receptacle and light is required?
Dennis Alwon said:I don't know of any code that requires a light for the a/c on the roof however,
iwire said:In my area it is some sort of mechanical code, if the HVAC unit has a gas fired furnace in it then we have to provide a service light. It is an issue that gets missed often. Kind of a last minute scramble to get it in for a sharp plumbing inspector. :smile:
emahler said:y'all are too nice...first post and a request for a code reference that simple...suckers...
Dennis Alwon said:Are you saying we should attack the op because he asked a simple question?:-?
iwire said:Cut him some slack, he is from NJ. :grin: He wants $ just to pick up the phone.:grin:
If one was installed, we would, I know from past that an outlet and Light must be wired in, need code Number to prove...Dennis Alwon said:I don't know of any code that requires a light for the a/c on the roof however, 210.63 is the art. for the receptacle
larrybader said:If one was installed, we would, I know from past that an outlet and Light must be wired in, need code Number to prove...
ultramegabob said:they should be required to supply an umbrella in case its raining...
Jim W in Tampa said:What am i missing here.If the thing is being serviced at night it is an 911 call and he needed flash light to get on roof anyways
Why should we spend this kind of added cost for something unlikely to ever be needed.
Any idea why it is required for gas fired furnaces. It seems if you are going to require it then it shouldn't matter what kind of furnace it is.iwire said:As I mentioned the code quicks in when there is a gas fired furnace in the RTU which in this area is almost all of them.
Dennis Alwon said:Any idea why it is required for gas fired furnaces. It seems if you are going to require it then it shouldn't matter what kind of furnace it is.
