iwire said:If this is going to turn into a ground up or down thread type thread it will not stay open long. :grin:
electricmanscott said:What order breakers are installed is exactly that.
e57 said:As you noted Bob - there is some sense to it 'listing wise' of load per stab - and most panels are full sized stabs at the top.....
Same here, and sometimes I mark the panel interior. This particular job was a basement, with exposed cabling, and even if other sections of the basement are finished, this utility area will never be.bigjohn67 said:We do it as Larry has shown above. However, we leave enough sheathing "IN" the panel to make a secondary marking. Marking it above the panel does not do much good when the sheetrock goes up.
peter said:And why don't the number book people make a book of labels "LINE" and "LOAD"? This would help with downstream GFCI circuits. Or a new color of tape -- such as HOT PINK -- to identify the hot, incoming line wires?
~Peter
Why not simply get a number book and number your wires?
