goldstar
- New Jersey
- Electrical Contractor
Just venting !!! If anyone else is running into this problem and you have a solution would you please share it ?
Today's sheetrockers aren't measuring for outlets and cutting a hole with a rock saw. Instead, they're using a Roto-Zip, plunging the bit into the sheetrock in an attempt to find the outside of the receptacle or switch box behind the piece of sheetrock they're installing, and cutting out the hole that way. The problem with this is that they frequently plunge the roto bit into the inside of the box and rip the wires to shreads.
I've tried asking them to shorten the length of the bit but it seems to fall on deaf ears. I usually end up splicing new wires onto short ones inside an already tight box. Any suggestions would be appreciated.
