jaylectricity said:All I can add about the ground rods is that you aren't supposed to cover them up. Drive them into the ground, attach your acorn and grounding electrode. Make sure the inspector can see the that you didn't saw off the top of your rod (to make it shorter and therefore less contact with the earth) and that you have the correct wire size.
celtic said:Whose to say that you didn't cut them...then unmercifully "mushroomed" the head?
